Document
I create a database is name is massages
For send message on the page for my user
if I want to upload a document o a picture how I can do that
i assume you want to save the file name to the database, see the following tutorial:
http://www.webassist.com/tutorials/Add-file-fields-to-Data-Bridge-insert-update-pages
Ok
But I want to send a document to specify user no to all user
create a form with a file field.
create a recordset and filter the recordset so that it returns the specified user, add the create email message server behavior.
in the universal email behavior, set the to address to use the recordset.
on the attachments section, select the Submitted file option and select the file field.
