Login system login display issue
I have built a login system with 3 users with unique id numbers, i want to display just user 1 data on the page. I have made a second recordset & filtered this with the ID filter but it doesn't seem to work?
try adding the following code at line 1:
<?php @session_start(); ?>
if you still have a problem, send a copy of the login and the page wit the recordset.
I have inserted this code & still nothing: <?php @session_start(); ?>
Attached is the files that i am using
the page i was mainly working on was specific.php
the session created by the login page is named:
SecurityAssist_UserID
in your recordset, you have used a session named UserID, change that to use the session created by the login page:
Is this correct Jason?
I have done the attached change & it doesn't seem to be working?
that looks correct.
I am currently working locally with mamp? will i need to upload & setup a mysql?
yes, in order to troubleshoot, you will need to upload.
Do i need to recreate everything again, i have amended the connection with the mysql details but i am getting the below error?
Table 'login_system.users' doesn't exist
The url is: http://nuhouse.ie/login/registration.php
you will need to export the users table from the local mysql server and import it to the remote server.
