MySQL vs MSSQL - having real problems with INNER JOIN
Thread began 1/08/2014 9:07 am by Nathon Jones Web Design | Last modified 1/09/2014 11:47 am by Patrice | 3926 views | 8 replies |
Jings, this is going to be tougher than I thought. I'm so used to MSSQL. :(
What is the issue with running an INNER JOIN select statement?
Here's what it used to look like in MSSQL:
SELECT dbo.LEDprods.LEDid, dbo.LEDprods.LEDdelete, dbo.LEDprods.LEDproductcode, dbo.LEDprods.LEDcatID, dbo.LEDprods.LEDfittingID,
dbo.LEDprods.LEDstyleID, dbo.LEDprods.LEDwattageID, dbo.LEDprods.LEDcolourID, dbo.LEDprods.LEDdimmable, dbo.LEDprods.LEDfrostedclear,
dbo.LEDprods.LEDlumensID, dbo.LEDprods.LEDsensor, dbo.LEDprods.LEDprice, dbo.LEDprods.LEDimg, dbo.LEDprods.LEDchipsID,
dbo.LEDwattage.LEDwattage, dbo.LEDstyle.LEDstyle, dbo.LEDlumens.LEDlumens, dbo.LEDfitting.LEDfitting, dbo.LEDcolour.LEDcolour,
dbo.LEDchips.LEDchips, dbo.LEDcats.LEDcat
FROM dbo.LEDprods INNER JOIN
dbo.LEDcats ON dbo.LEDprods.LEDcatID = dbo.LEDcats.LEDcatID INNER JOIN
dbo.LEDchips ON dbo.LEDprods.LEDchipsID = dbo.LEDchips.LEDchipsID INNER JOIN
dbo.LEDcolour ON dbo.LEDprods.LEDcolourID = dbo.LEDcolour.LEDcolourID INNER JOIN
dbo.LEDfitting ON dbo.LEDprods.LEDfittingID = dbo.LEDfitting.LEDfittingID INNER JOIN
dbo.LEDlumens ON dbo.LEDprods.LEDlumensID = dbo.LEDlumens.LEDlumensID INNER JOIN
dbo.LEDstyle ON dbo.LEDprods.LEDstyleID = dbo.LEDstyle.LEDstyleID INNER JOIN
dbo.LEDwattage ON dbo.LEDprods.LEDwattageID = dbo.LEDwattage.LEDwattageID
WHERE (dbo.LEDprods.LEDdelete = 0)
Here's what I changed it to for MySQL:
SELECT LEDprods.LEDid, LEDprods.LEDdelete, LEDprods.LEDproductcode, LEDprods.LEDcatID, LEDprods.LEDfittingID,
LEDprods.LEDstyleID, LEDprods.LEDwattageID, LEDprods.LEDcolourID, LEDprods.LEDdimmable, LEDprods.LEDfrostedclear,
LEDprods.LEDlumensID, LEDprods.LEDsensor, LEDprods.LEDprice, LEDprods.LEDimg, LEDprods.LEDchipsID,
LEDwattage.LEDwattage, LEDstyle.LEDstyle, LEDlumens.LEDlumens, LEDfitting.LEDfitting, LEDcolour.LEDcolour,
LEDchips.LEDchips, LEDcats.LEDcat
FROM LEDprods INNER JOIN
LEDcats ON LEDprods.LEDcatID = LEDcats.LEDcatID INNER JOIN
LEDchips ON LEDprods.LEDchipsID = LEDchips.LEDchipsID INNER JOIN
LEDcolour ON LEDprods.LEDcolourID = LEDcolour.LEDcolourID INNER JOIN
LEDfitting ON LEDprods.LEDfittingID = LEDfitting.LEDfittingID INNER JOIN
LEDlumens ON LEDprods.LEDlumensID = LEDlumens.LEDlumensID INNER JOIN
LEDstyle ON LEDprods.LEDstyleID = LEDstyle.LEDstyleID INNER JOIN
LEDwattage ON LEDprods.LEDwattageID = LEDwattage.LEDwattageID
WHERE (LEDprods.LEDdelete = 0)
Now, before you point out that you can't have a field name called the same as the table name, I've changed that but it just doesn't work. No errors are reported, it's just that no table rows are shown.
Is there something obvious that I've missed here. Please bear with my btw. I really want to port everything to PHP/MySQL and it's going to take me some time to adjust.
With that in mind, can anyone point me in the direction of a good website or forum for these types of headaches, ie. one that helps peopel make this transition from Classic ASP and MSSQL to PHP and MySQL?
Much appreciated.
NJ
bear in mind that different join types return different results.
with an inner join, a result will only be returned if there is a match on both sides of the join predicate.
with the number of tables that you are joining, I'm going to bet that at least one of the join pairs is not making a match so is not returning a result.
to trouble shoot, change the select to:
SELECT *
then add one join at a time:
FROM LEDprods
INNER JOIN LEDcats ON LEDprods.LEDcatID = LEDcats.LEDcatID
test that then add the second:
FROM LEDprods
INNER JOIN LEDchips ON LEDprods.LEDchipsID = LEDchips.LEDchipsID
test again and so on.
once you stop getting a result revert to a simpler query with only the last join that you added.
your jumping in on the deep end with such a complex query. Get your feet wet with something simper first.
also look into a GUI SQL Tool such as Heidi SQL for building queries with a visual builder.
good advice, as ever
Thank you Jason.
I've installed and configured HeidiSQL but, unlike SQL Server Management Studio, I can't easily see how I add tables to create a View, which is how I'm creating this INNER JOIN query. In SQLSMS I can simply select, from a list, all of the tables I want to use in my query (A view is just another name for a query table, right?). Where, in HeidiSQL, is the visual builder?
Thank you again for all your help Jason. My intention is to purchase eCart in the next month or two and really push on with developing in PHP.
I only hope that it, too, doesn't die like Classic ASP did.
Oh, and with that in mind, is there an upgrade option for eCart? I'm currently using version 4.5.2.
Much appreciated.
NJ
there is a query builder on the query tab
http://www.heidisql.com/screenshots.php?which=query
or perhaps you want more of a automated builder like is available in Navicat:
http://www.navicat.com/manual/online_manual/en/navicat/linux_manual/QueryBuilder.html
the upgrade price for eCart will be $99, if you are interested, there will be a live demo of eCart 6 this saturday.
GMT for eCart demo?
Hi Jason. Sorry what time, GMT, is the eCart demo?
http://www.webassist.com/watch-and-learn/ecart-6-live-tour
it's at 9am - 11am PST, So that would be 5pm - 7pm GMT if my calculations are correct.
PatriceWebAssist
Looks exciting!
Displays are all responsive now and optimize your shopping cart for smartphones and tablets, in addition to desktop displays.
Checkout wizard is now tab based, making set up of your checkout pages much more efficient (no longer a 12 step process!)
Will the tour be available later also?
If my math is right noon on EST time. Looking forward to it.
When will it be available to upgrade?
Yes a recording of the tour will be made available.
Yes, 9am PST is 12PM EST
We hope to have the upgrade available right after the tour, but are still working out some issues, so no guarantees.
PatriceWebAssist
Excellent. Very excited about the upgrade.
Happy to beta test on Mac; I will be upgrading for sure.
