email wont send? but it did the first 5 times?
I added the server behavior to send email and it worked, It then just stoped working, i removed and reinstaled but still nothing. I believe i have the latest build and when i use your test snipet in the <body> i get the following
array(13) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["team_id"]=> string(1) "1" ["team_co_id"]=> string(1) "1" ["seed_last_id"]=> int(58) ["waue_success_1_Status"]=> string(7) "Success" ["waue_success_1_Index"]=> int(1) ["waue_success_1_From"]=> string(35) "Ryan Pratt " ["waue_success_1_To"]=> string(22) "info@mediamasons.com" ["waue_success_1_Subject"]=> string(5) "Hello" ["waue_success_1_Body"]=> string(454) " --WAMULTIBREAKWA Content-Type: text/plain; charset="UTF-8" Content-Transfer-Encoding: 8bit Welcome, Ryan Pratt You have been registered as a Member. We will contact you shortly to share the benifits you now have access to. --WAMULTIBREAKWA Content-Type: text/html; charset="UTF-8" Welcome, Ryan Pratt You have been registered Member. We will contact you shortly to share the benifits you now have access to. --WAMULTIBREAKWA-- " ["waue_success_1_Header"]=> string(387) "MIME-Version: 1.0 Content-Type: multipart/alternative; charset="UTF-8"; boundary="WAMULTIBREAKWA" From: Ryan Pratt Reply-To: rpratt@mediamasons.com Return-Path: test@mediamasons.com X-Sender: Ryan Pratt X-Priority: 3 Date: Wed, 08 Jan 2014 02:02:00 +0100 (CET) Message-ID: <1804869860.c5fd9315cd7f2a7cb61bd5ff4032b829@mediamasons.com> " ["waue_success_1_Log"]=> string(51) "Sending To: test@mediamasons.com... Success
