Problem with Quantity update. I have set up ecart 5.07 through "confirm" checkout on Win 8.1.
Thread began 1/07/2014 10:44 am by Ray | Last modified 1/07/2014 1:33 pm by Jason Byrnes | 2691 views | 11 replies |
Ray
When I change quantity on the cart page and hit "update" the page is redirected to "checkout" instead of staying on the cart page as happened before I used the checkout wizard. This will be a problem for the customer, as they will not be able to see the items and cost before proceeding. Also if you hit "enter" on the keyboard instead of "update" another page of the site appears - rather confusing. This site is still on a local server at this time. How can I fix these issues?
I'll need to see this happen in a browser, you will ned to publish the site, also send a copy of the cart display page so i can see the code.
Ray
Quantity issue update
  I'll need to see this happen in a browser, you will need to publish the site, also send a copy of the cart display page so i can see the code.
see PM
Ray
  see PM
The redirect occurs when the quantity is updated. The browser takes you to the checkout page instead of staying on the cart page.
see PM
Ray
Quantity issue
  see PM
the zip file still contains the pieces of the code posted to a text file.
please attach a copy of the original cart page so I can see the entire page code in context.
put the cart.php file into the zip, don't past the page code into a text file please.
just compress the php file to the zip archive.
Ray
edit the following code at line 85:
if ($_SERVER["REQUEST_METHOD"] == "POST") {
if (isset($_POST["NewDesignerKarenCart_Checkout"]) || isset($_POST["NewDesignerKarenCart_Checkout_x"])) {
so it will only preform the checkout redirect if the checkout button is pressed.
