My PowerMessenge login screen is scrambled.
Thread began 1/06/2014 10:14 pm by GerhardC | Last modified 1/07/2014 6:14 am by Jason Byrnes | 706 views | 1 replies |
GerhardC
I have installed PM at a new host provider and have successfully gone through the wizard.
But on the http://www.everydaybeliever.org/powermessenger/admin_pm/index.php page, I get three error messages right at the top of the page:
Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Australia/Perth' for 'WST/8.0/no DST' instead in /home2/everyd10/public_html/powermessenger/webassist/themes/Default/images/installed.png on line 2
Warning: strtotime() [function.strtotime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Australia/Perth' for 'WST/8.0/no DST' instead in /home2/everyd10/public_html/powermessenger/webassist/themes/Default/images/installed.png on line 2
And I get probably only a fifth of the login window that displays.
This is a hosting issue.
In the php.ini file there is a setting for the time zone:
date.timezone
this has been left blank.
you should contact the hosting provider to them update the php.ini file and set the date.timezone setting.
alternately, you could edit the webassist/themes/theme_open.php file and add the following code at line 1 to set the timezone, but it would be better to have it set in the php.ini
<?php date_default_timezone_set('Australia/Perth'); ?>
