wrong description displaying in cart
Thread began 12/22/2013 6:11 pm by Sam Barnhart | Last modified 2/26/2014 9:27 am by Jason Byrnes | 1844 views | 5 replies |
Sam Barnhart
The cart is displaying the Long description when a customer places an order using the product detail page.
But when they use the product listing page (the first page the displays all the products) the cart then displays the short description.
None are displaying the cart description.
How do I change so that the cart is displaying the cart description no matter what page the order is placed.
Attached is the code from the product detail page.
Thanks, Sam
open the server behaviors panel.
in the server behaviors panel, double click the eCart Add to cart from recordset behavior to edit it.
on the bindings tab, select the description column and click the lightning bolt icon next to value. from the bindings panel, select the cart description column from your recordset.
Sam Barnhart
Still need assistance
I tried the instructions several times and after the make the change it does not seem to change the behavior.
Can you help me with the two open issue this one and the add to card redirect issue.
Thansk, Sam
Sam Barnhart
Info request supplied in private message
Please see private message
you have another thread open with the same question, i will address this one in the other thread.
