How to modify a page that's already created?
Thread began 12/10/2013 8:30 am by FPhu61701534 | Last modified 12/10/2013 8:44 am by Jason Byrnes | 466 views | 1 replies |
FPhu61701534
There are times when I have to modify the Update or Insert page after Webassist created them because I forgot to include a field or I need to change a field from text to menu. Let's say I want to change a field from text to menu. I would copy the menu HTML (and whatever PHP) codes to replace the text field. Then I would change the id, name and whatever. This is tedious and sometimes it results in error.
So my question.., is it possible to re-open a generated Update or Insert page in Webassist so that I can modify the fields and then have the page re-generated?
The best way to do this is to save your settings as a preset.
If you need to make changes, delete the pages that where initially created, re run the wizard, select the saved preset, and make changes to the preset.
save your changes as a preset again so that you have a starting point if you need to make further changes.
