update failure
The attached form file does not error out but it also does not update the record? I'm missing something, what?
thanks,
Nick
thanks,
Nick
is there a record in your table where the id column value is 4269?
Yes I just coded the test record ID. Apparently the column name pre_1_PAID_reg was not acceptable! I changed the name to pm1PD_reg and the form worked.
What could be wrong with the name?
Nick
I would need to troubleshoot directly to be able to answer that question.
In my experience, DW can be flakey with column names that use underscores in them. I prefer to stay away from underscores in column names and use the camelCase naming convention instead.
