I need to make a navigation menu and I would like to build something similar to: www.musiciansfriend.com, www.Adobe.com or www.Amazon.com menus. Can you tell me which applications or extensions I would need to produce something similar with column sp
Thread began 11/28/2013 11:06 am by Mark | Last modified 11/30/2013 9:47 am by Mark | 487 views | 2 replies |
Mark
I need to make a navigation menu and I would like to build something similar to: www.musiciansfriend.com, www.Adobe.com or www.Amazon.com menus. Can you tell me which applications or extensions I would need to produce something similar with column spans an
I need to make a navigation menu and I would like to build something similar to: www.musiciansfriend.com, www.Adobe.com or www.Amazon.com menus. Can you tell me which applications or extensions I would need to produce something similar with column spans and pictures?
You could use menu writer in Design Extender to create the basic menu structure of the categories and a second level popup.
after the menu is created, edit the menu.php file to add the images and other content to the second level popups.
Mark
Thanks Jason!
