Update page adding a second file extension when new image uploaded
Thread began 11/25/2013 1:15 pm by Lon Winters | Last modified 12/17/2013 2:19 pm by Jason Byrnes | 791 views | 3 replies |
Lon WintersBeta Tester
The insert page works fine, but on the update page, whenever I upload a new image - whether it's a new or existing file name, the image name in the database always show an extra ".jpg" (imagename.jpg.jpg). I'm pretty sure I have all the bindings correct. In the Upload behavior, the file name is bound to the form file field, and the hidden field is bound to the recordset image column. In the Update behavior, the image column is bound to the UploadStatus - Server File Name.
In the previous screen, the dropdown is set to "Overwrite" if file exists - I have not tried to change this as it occurs even with a new filename.
Any ideas? Everything still works fine whereever the images are displayed in the site - eCart, but I'd rather have it not do this.
Sorry for the extended delay in replying. The issue is not causing any real problems with the images, plus, I'm sure I don't have the updated compatible version for DWCC - so I certainly don't expect you to troubleshoot this particular issue. It's probably similar to the thumbnail renaming issue and I can most likely figure it out by editing the helperphp file. However, if you do want to investigate that it may help improve the product or some other reason, please let me know and I will provide all the details. Thank you!
entirely up to you, if you want me to look into it, provide the requested details. if not, that's ok too.
