Adding content to Power CMS under connections it says none and when I try to define the options are greyed out?
My solution was pretty simple. I needed the database extension for CC. All is well now
make surre that you have your site set up for dynamic development, see the following tutorial for details:
http://www.webassist.com/tutorials/Define-a-dynamic-site-in-CS5
also, make sure that you have a php from your site open when you try to use Power CMS builder.
