Group access problem
Thread began 11/21/2013 8:36 am by Massimo | Last modified 11/21/2013 11:08 am by Jason Byrnes | 510 views | 3 replies |
Massimo
Hi, I have a in group autentication that not work and the page is not protect.
I set User level Session and all was explained in tutorial but nothing and I've used it several times in group autentication without any problems.
something wrong. Need help
I attached the example file that not work in app folder
in the Amm e Super am group definition you have an empty member.
edit the group definition try to select the space under the last group member, that is a member that is empty, you will nee to remove the empty member.
Massimo
Thanks! now work.
another question about level auth.: is there a difference if for the levels using a more complex numbers instead of 1,2,3? The safety is higher or is the same?
there is no difference in using 1,2,3 or 1101,1202,1303 or any other number scheme.
