transparent or white background, and transition
hi
i need to change a slide show to have transparent background (or white)
and i want the transitin to be more fade/dissolve like the other slideshows.
i will post in pm the link and info.
hi
Hi
thank you.
Im going to be making some other layouts of galleries and will need to change the background to white on those as well. can you tell me what line of code i need to look for to make this change so i can do it myself in the others?
in the gallery/galleries/slideshow_wide/index.php file i change the following line:
echo(pg_getCachedResizedImageHTML(ob_get_clean(), "" . realpath( $galleries_dir ."../images/" . $row_gallery['folder_name'] . "/cache"), "". $fullsizeInfo['resize'] ."", "",true, false, $rotateAngle, $watermarkOpts));
echo(pg_getCachedResizedImageHTML(ob_get_clean(), "" . realpath( $galleries_dir ."../images/" . $row_gallery['folder_name'] . "/cache"), "". $fullsizeInfo['resize'] ."", "#FFFFFF",true, false, $rotateAngle, $watermarkOpts));
Then in the images folder, locate your gallery and delete the cache folder to have the images regenerated.
