More tables in one database
Thread began 8/18/2009 1:55 am by andy95879 | Last modified 8/18/2009 8:44 am by Jason Byrnes | 1371 views | 1 replies |
andy95879
Hi
I can't fault PowerCMS as a simple easy to use CMS system. My only issue is that it's not quick or easy to install mulitple instances on the same database. It would be a nice addition if you can add a prefix to the tables?
Instead of using the same database for each PowerCMS instance, you should create new databases if you are going to to host multiple PowerCMS Instances on the same MySQL server.
