Cannot connect to server when trying to Insert Content with Power CMS
When I try to insert content, the Connection is grayed out. If I click on Define connection and then test it, I get an error. The error is: "An unidentified error has occurred" and then I get an error that says "Errors occurred when connecting to your database." I know the connection string is correct. It is being hosted on Go Daddy. I host name, database name, user name, and password ... all correct. I've copied from directly from Go Daddy. Thank you.
