Update Record Server Behavior - Increment Column
Thread began 11/04/2013 4:11 pm by dlovas275157 | Last modified 11/04/2013 5:39 pm by dlovas275157 | 626 views | 2 replies |
dlovas275157
I have a simple form wrapping a download button. When the user click the download button (the form submit button), the form links you to a PDF. But i need it to also run an Update Record Server Behavior to increment a download count in my database
The increment is not working in my update record server behavior. Not sure why, attached is my code.
formTest.php.zip
use the file download behavior instead of a link.
in the file download settings you can specify a download count column.
dlovas275157
Jason,
I couldn't use the File Download SB, as it requires the file to reside on the same domain.
After rebuilding a couple times, I was able to get it working. I think the issue was I had my count column in my database set to default: NULL and I had to change it to default: 0 or 1 for the increment to begin.
...and the increment value had to be:
<?php echo $row_rsDownloadCount['downloadCount']+1; ?>
instead of
<?php echo $row_rsDownloadCount['downloadCount']++; ?>
for some reason.
-DL
