wysiwyg not loading properly
Thread begun 11/04/2013 5:19 am by gruant2000381341 | Last modified 11/04/2013 11:43 am by Jason Byrnes | 3500 views | 5 replies |
gruant2000381341
When I click edit, the wysiwyg toolbar shows up, but not the contents box. Only happening in IE10, Chrome and Firefox are ok. What do I need to edit so it will work on IE?
I should also point out that this is the standalone pcms2 and not the builder version.
you will need to update the CKEditor Files manually.
in the webassist/ folder, rename the ckeditor folder to ckeditor_bak
On this page:
download
click the button to launch CK Builder. Select to use the Full Preset, and the Kama Skin.
Copy the downloaded CKEditor folder to the webassist folder in your site.
from the ckeditor_back folder, copy the following three files:
ckeditor.php
ckeditor-php4.php
ckeditor-php5.php
and paste them in the new ckeditor folder.
you will need to clear the browsers cache to see the updates take effect.
gruant2000381341
Are any of the list of plugins (the list on the right hand side) necessary from the builder for pcms?
the full preset will contain all the needed plugins.
gruant2000381341
okay now something else isn't working
Okay, that part is sorted.
Now upon testing, I am not able to upload images via kfm in Internet Explorer.
I did the fix for the <script type="text/javascript" src="j/all.php"></script>
No dice, I am not getting the "please wait" screen just an empty one.
It works via Chrome, and it is creating the Files folder....just nothing with IE
screen shot attached
edit the webasssist/kfm/index.php file, add the following code to the head section:
<meta http-equiv="x-ua-compatible" content="IE=9" >
