Forms >> Insert CAPTCHA shared.js error
Thread began 10/31/2013 10:24 am by Andrew Dodd - ADDIGITAL | Last modified 11/01/2013 8:24 am by Andrew Dodd - ADDIGITAL | 2302 views | 9 replies |
I'm using Dreamweaver CC.
When I try to insert a CAPTCHA, the process is riddled with errors, the like of which is shown below. Eventually, the Captcha is placed.
I have the latest version of eCart, DE and DB - these are the only extensions I have apart from Adobe's Deprecated Panel, uninstalled and reinstalled in the prescribed order and have deleted the cache file..
Extremely annoying and disruptive to workflow.
Any ideas?
TIA
Andrew
Any ideas
Reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
Hi Jason,
I'd already done that - but, I did it again, anyway! It made absolutely no difference.. :(
Do you have a plan B?
Andrew
What extensions including the version numbers are installed?
Close Dreamweaver, then in the users configuration folder, try deleting eh folder named wrokspace.
Deprecated Panel Support 1.0.0
eCart 5.07
Design Extender 1.1.5
Data Bridge 1.1.4
Deleting the Workspace folder didn't help either!
did you delete the workspace folder:
Hi Jason,
Just to confirm, I DID delete the Workspace folder - it made no difference.
Andrew
Hi Jason,
I managed to solve this myself (I think) after some research - by removing all the extensions and recreating the configuration folder in ~/Library/Application Support/Adobe/Dreamweaver CC/en_US.
Might be worth creating a sticky to do this as a last resort, if all else fails?
Best,
Andrew
That was going to be my next suggestion, it is step 12 of the adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
As much as it solved the majority of the problems, editing the catcha still causes the problem to reappear, but it's not as annoying - yet :)
Andy
