Datepicker date format - need help
Thread began 10/31/2013 9:16 am by sjones435326 | Last modified 10/31/2013 11:52 am by Jason Byrnes | 1121 views | 3 replies |
sjones435326
I'm sure this is user error somewhere along the line, but I'm trying to get the date picker to layout in this format yyyy-mm-dd. I have changed it in the events_insert.php file that was created using DataAssist. I have the date picker correctly displaying the format that I want but I continue to get an error of "Invalid Format" when trying to insert data.
I'm using this particular page for an Events calendar where I need to display the query results by comparing the dates using the year, month and day. I will include the insert file that I'm using.
change line 172:
var event_date_Spry = new Spry.Widget.ValidationTextField("event_date_Spry", "date", {isRequired: false, format:'yyyy/mm/dd', validateOn:["blur"]});
var event_date_Spry = new Spry.Widget.ValidationTextField("event_date_Spry", "date", {isRequired: false, format:'yyyy-mm-dd', validateOn:["blur"]});
sjones435326
Thank you Jason, once again you have bailed me out!
you're welcome.
