Web assist "insert new form"
Thread began 10/30/2013 4:04 pm by russb335115 | Last modified 11/05/2013 1:43 pm by Jason Byrnes | 1208 views | 7 replies |
russb335115
I have a form on a page and when submitted I get this error:
Fatal error: require(): Failed opening required 'Block.php' (include_path='.:/usr/lib/php6') in /homepages/19/d403739231/htdocs/champPerformance/webassist/email/mailformatting_php.php on line 151
The form is being sent to an email address.
this means that there are some files that have not been uploaded to the server.
make sure to upload the entire /webassist/email/ folder
russb335115
okay I did that and know I get this message in Dreamweaver (see image upload)
Also the form is not being submitted.
that notice means that there where form elements on the page that used spry validation originally, but they have since been removed and the spry validation is left behind.
you will need to delete the spry validation for the elements that no longer exist.
send a copy of the form and a link where i can see the problem to troubleshoot why it is not submitting.
russb335115
How do I set the function to "on success go to the success page" on the form submit function?
on success of what?
is the form a login form? successful login? then use the Security Assist authentication server behavior to process the form, and set the success redirect in the authenticate user behavior.
is the form sending an email? if so, edit the Universal Email server behavor to set the go to page after the email is sent.
russb335115
Thanks, that info was very helpful.
My only other issue is that the email being sent isn't making it to my client's email. I have the CC set to my email and that's working so i know the form is being submitted. Can you help?
if it is going to one address but not the other, than it is an issue on the SMTP Server.
you will need to contact the host to have them look into the SMTP Server error logs to determine why the email is not being relayed to the clients address.
