I have 70 fields in my form I want to send same field in PDF attachment who will fill form
Thread began 10/29/2013 3:12 am by anonymous | Last modified 10/29/2013 12:00 pm by Jason Byrnes | 570 views | 1 replies |
anonymous
I have 70 fields in my form I want to send same field in PDF attachment who will fill form so they can print and send me same
same time data should save in database and I get confirmation with all fields which user inserted in form is it possible
you will need to create the PDF file and upload it to your server.
Create the form page and add the Create Email Message behavior to send the email, If you select to use one of the templates for the email body, the form data will automatically be added to the email. On the attachments tab, add the PDF as an attachment.
Add the Data Assist insert record behavior to store the form data to your database. On the Server behaviors panel, click the plus button, select webassist -> Data Assist -> Insert Record -> Insert Single record.
on the bindings tab, select each column, click the lightning bolt next to value and select the corresponding form field.
