Unable to pass Session Variable from Update Form Page to Second Update Form Page
Thread began 10/27/2013 10:48 pm by dlovas275157 | Last modified 10/28/2013 3:32 pm by Jason Byrnes | 540 views | 3 replies |
dlovas275157
I have attached the two update form pages. I am building a 2-part update.
Problem:
I am trying to "on form submit" set session variable named "WADA_Update_mre".
THen I need to retrieve that Session variable on the second update page and filter a recordset named rsProperty.
I cannot get the session variable to pass to the second update page.
Please let me know what i am doing wrong (see attached code).
thnx
Daniel
Archive.zip
your code to set the session:
if($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["WADA_Update_mre"] = "".$row_WADAmre['autoNum'] ."";
is at lines 11- 16. this is before the code for the WADAmre recordset which is at line 64 - 72.
the session must be set after the recordset, not before.
dlovas275157
Jason,
That worked. Thanks again for your help.
Daniel
you're welcome
