Fatal framework error
Thread began 10/25/2013 9:37 am by jo271221 | Last modified 10/27/2013 9:14 am by Jason Byrnes | 2644 views | 7 replies |
jo271221
On this page: http://www.wantabefamous.com/index1.php I get an error. I found some resolutions from 2010 but nothing recent.
Fatal error: Maximum execution time of 30 seconds exceeded in /home/wantabef/public_html/webassist/framework/framework.php on line 162
None of the pages using this template/theme work. They all get the error.
Thank You!
try adding the following code at line 1 of the webassist/framework/framework.php file:
<?php ini_set('max_execution_time', 300); ?>
jo271221
Now I get this error -
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer's network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
framework.pdf
jo271221
Plz see private
Private msg
You applied the theme to the template. which caused an infinite loop I commented the theme code from the template to correct the problem.
jo271221
Fatal framework error resolved.
Thank you for resolving this issue!!
you're welcome.
