Menu disappearing when hovering over a Nivo Slider?
Thread began 10/24/2013 1:20 pm by Nathon Jones Web Design | Last modified 10/25/2013 7:49 am by Jason Byrnes | 1438 views | 3 replies |
On the following page we have a nivo slider slideshow top left, under the first 3 buttons in our CSS MenuWriter menu.
www.babyfish.co.uk
When you hover over any of the first 3 buttons, and then try to select a sub-menu, the whole menu disappears. A good example of this is if you hover over "Toddler Gifts" in the main menu you'll that its buttons cover some of the slider and some don't. If I hover over that sub-menu, on an area that's not over the nivo slider, it doesn't disappear.
Hoping that's a known issue with a known fix. Thank you.
Regards
NJ
in the http://www.babyfish.co.uk/CSSMenuWriter/cssmw/menu.css file, set the ul#cssmw css to:
ul#cssmw {
cursor: default;
list-style-type: none;
margin: 0;
padding: 0;
z-index: 999999;
position: relative;
Fixed.
Thank you Jason. Worked perfectly.
you're welcome.
