File upload
Hello,
I just create a File for file upload...
I want to know if I can upload any word document or PDF files please..
If the answer is no, how can I make happen please???
Hello,
The File Upload behavior in Data Bridge can upload any kind of file to the server, word, PDF, image etc.
I got it, Thanks...
Can file uploaded be sent to email box in stead of my server???
Yes, in universal Email, you can attach the file to the email.
Sorry for asking again but how I do that???
there are 2 ways to attach files to an email
1) Dont use the file upload behavior and select the Submitted file option on the attachments tab of the UE behavior
2) Use the file upload behavior to save the file to the server. Then on the attachments tab of the UE behavior, select the enter value option.
Click the lightning bolt icon and expand the Uploaded Files binding group, select the Server Directory binding. Copy the code for the server directory binding, then select the Server file name binding. lastly, copy the server directory code in front of the server file name binding code.
Hi Jason,
Two more questio... How can I change the this line
Resume has been sent successfully!
10-24-2013 | 12:39 PM CT>>>>>>> HOW DO I CHANGE THE EST TIME METHOD??????
ALSO WHEN I RECEIVED AN EMAIL IT SAYS FROM ON KNOW SENDER, HOW CAN i HAVE SHOW WHO IS SENDING MAIL???
PLEASE
add the following at line 1 of your page:
<?php date_default_timezone_set('America/New_York'); ?>
in universal email, you need to specify a valid email address for your domain in the from address.
if you click the from button, you can bind the return address to the address form element in your form, that will allow the email to use a valid from address, but replying to the email will reply to the person that filled in the form.
Thank you , Jason I will give it a try now
