insert
Thread began 10/23/2013 10:40 am by Javier | Last modified 10/23/2013 3:19 pm by Jason Byrnes | 1288 views | 11 replies |
Javier
insert
I create a insert single record that put data in my database
I can create that same file.xml and inserted in a folder in the ftp
I dont follow, please provide a more detailed explanation of what you are trying to accomplish.
Javier
OK,
I create a insert single record to insert data into my database
and I want when I click submit send that information into a folder in my ftp in xml format
you would need to hand code creating the XML file on form submit
i found a few examples through google on the stack overflow site:
http://stackoverflow.com/questions/2038535/php-create-new-xml-file-and-write-data-to-it
Javier
Where I put that hand code
In the file that inserts the data to the database.
Javier
In the example yo send me I copy that same code
I create the insert single record with webassist
no, that is an example of how to create a xml file using PHP. it is only an example and should be copied line for line, you will need to make the appropriate adjustments to the code based on your form.
we do not offer support for this though.
Javier
Ok but can you tell me where exactly I put that code
before the insert record code.
