html editor instance not visible to some users
Thread began 10/14/2013 7:47 am by CraigR | Last modified 10/15/2013 5:44 am by Jason Byrnes | 1395 views | 5 replies |
CraigRBeta Tester
i have an instance of htmleditor on a page and some users claim not to be able to see the edit field.
After checking browser compatability, i believe the problem is down to a security issue, but cannot see why.
The page has member only access restrictions, if I log in as an admin, I see the editor, if I log in as member I don't see it
Is there a setting in the ckeditor folder I am missing ?
CraigRBeta Tester
OK
see PM
CraigRBeta Tester
I found the cause of the problem, - though the symptoms were strange.
The problem lay in the default skin setting for the CK editor being set as kama.
I remember when I updated to the latest version, I had issues with not seeing the editor, which was because kama css was not in the folder, but an alternative theme, moono was, so I changed the editor skin to moono and all is well.
I still can't account for being able to see it as admin and not as member, but I won't dwell on that too much.
Job done, thanks for looking into it for me.
Ok, glad to hear you found the problem, cant say why it would have worked for some, but not for others, perhaps browser cache is all I can think.
