Error when using PowerCMS: Unknown column 'C2.ContentInlineToolbar' in 'field list'
Thread began 10/07/2013 2:34 pm by sandy170299 | Last modified 10/09/2013 5:54 am by Jason Byrnes | 1169 views | 6 replies |
sandy170299
I have created a site based on a DW template and converted it with Framework Builder. I just created my first page by inserting content from Power CMS, but I'm receiving this error when I try to preview it in a browser: Unknown column 'C2.ContentInlineToolbar' in 'field list'
Thank you.
sandy170299
Now I'm getting another error: Table 'sergio.pcms2_toolbarpresets' doesn't exist
It appears as if my tables are mismatched after an upgrade. How do I fix this without destroying everything I've done?
Thanks.
See the following tutorial for details on updating a previous CMS installation to the current version:
http://www.webassist.com/tutorials/Updating-Design-Extender-s-PowerCMS-Installations
sandy170299
I followed the tutorial, copied all of the new files to my site, ran the script to update the database, moved this code (<?php require_once("WA_CMS/WA_CMS.php"); ?>) between the head tags, and now I'm receiving the following error:
Warning: require_once(../WA_CMS/library.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\GBA\WA_Globals\WA_Globals.php on line 4
Fatal error: require_once() [function.require]: Failed opening required '../WA_CMS/library.php' (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\GBA\WA_Globals\WA_Globals.php on line 4
see PM
sandy170299
see PM
See PM
