Repeat Region not working
Thread began 10/04/2013 12:03 pm by wbrooks199805 | Last modified 10/04/2013 2:22 pm by Jason Byrnes | 431 views | 5 replies |
wbrooks199805
I am following the tutorial create new pages from template. I am on where you add the "create your results page" number 28. I don't have Data Objects So I have tried go Server Behaviors, WebAssist, DataAssist, repeat Selection and it doesn't work. It works for one recordset. What do you need to look at?
I have updated by adding the page for you to look at. BTW, when I add the repeat region, all the results disappear
What version of Dreamweaver are you using?
What do you mean by:
"It works for one recordset."
I only see one recordset on your page? the recordset code is duplicate, but there is only the one recrdset named news.
for the code in the repeat region:
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'ISCI latest News', 'ISCIlatestnewstitle', false, $row_iscinewsRS['ContentPageSetOrder'] );
you refer to a recordset named iscinewsRS but this recordset does not exist on the page.
wbrooks199805
Update
I'm in 13.1.. cc.
"It works for one recordset." means if I don't add the repeat region, I see one record set. I have set up two pages with different titles for testing in PowerCMS
see private message
iscinews_results.php.zip
change:
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'news', 'ISCIlatestnewstitle', false);
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'news', 'ISCIlatestnewstitle', false, $row_news['ContentPageSetOrder']);
wbrooks199805
AS usual
Outstanding Support! Thanks Jason!! That did the trick.
glad to hear it is working.
