Help in Displaying Repeat Region in Universal Email
Thread began 10/01/2013 7:04 pm by anonymous | Last modified 10/03/2013 10:48 am by Jason Byrnes | 22444 views | 3 replies |
anonymous
Hi. I need help with displaying the repeat region from the attached form in the attached email. The form was generated with Data Bridge, and the email was generated with Universal Email. I also would like each submission of the form to generate a unique "estimate" ID in the subject line of the subsequent email -- without the use of a database key. Sequential numbers for the ID would be fine. Any help would be greatly appreciated.
Thanks,
Heather
I dont follow. What would you like the repeat region to do?
For the ID, you could use the Security Assist random Password generator.
open the bindings panel, click the plus button and select security assist random password. then add the random password binding to the email body.
anonymous
Hi, Jason. I would like the data in the form's repeat region to display in the email body. Right now, I can only get the data outside of the repeat region to display. Thanks in advance for your help.
instead of using the count variable for the form element names in the repeat region:
<input type="hidden" id="Price_<?php echo($count); ?>" name="Price_<?php echo($count); ?>" value="<?php echo $row_WADAestimate['PricePerUnit']; ?>" />
use the ID column from recordset. For example:
<input type="hidden" id="Price_<?php echo $row_WADAestimate['ProductNo']; ?>" name="Price_<?php echo $row_WADAestimate['ProductNo']; ?>" value="<?php echo $row_WADAestimate['PricePerUnit']; ?>" />
In the template file, add the following code at line 1:
<?php global $row_WADAestimate; ?>
Then you can loop through the form elements using this code:
<?php do { ?>
<?php echo((isset($_POST["Price_".$row_WADAestimate['ProductNo'].""]))?$_POST[""Price_".$row_WADAestimate['ProductNo']."""]:"") ?>
<?php } while ($row_WADAestimate = mysql_fetch_assoc($WADAestimate)); ?>
