ajax with image uploads
Thread began 9/24/2013 7:34 pm by kdavid379212 | Last modified 9/25/2013 12:00 pm by Jason Byrnes | 534 views | 1 replies |
kdavid379212
Hello,
I'm wondering what the trick is to getting the file manipulation portion of Email to work when using ajax. I have a file (___Untitled-5.php) that seamlessly uploads images to the server when used by itself. It fails to do anything, however, when called via an ajax javascript function. I've attached both files so that you can verify the results.
Thanks!
___Untitled-5.php
___Untitled-6.php
You need to use jquery to make the ajax call to the upload page, nit just strait ajax XML request. See stack overflow for details:
http://stackoverflow.com/questions/16875145/load-content-from-other-php-files-in-main-page-with-ajax-using-onclick
