Image File Size Requirement
Thread began 8/17/2009 11:38 am by mark292970 | Last modified 11/16/2009 9:16 am by pete268226 | 1315 views | 2 replies |
mark292970
Good Afternnon,
I am wondering if anyone knows what the correct image size should be when uploading a product to the Powerstore? Im sure it can vary but I'm looking for the optimal size dimensions the image should be.
Mark
The power store will set the size of the large images to 400 x 400 and the thumbnails to 200 x 200. if the image is smaller than 400 x 400, there may be some distortion on the large image that is created.
pete268226
Don't forget that if you change the Products_Insert.php upload dimensions, that you also should make those same changes in the Products_Update.php file. This way, if you update an existing product, it'll take on the same dimensions as your initial creation.
