I updated and not it does not work
I updated my suite (CSS Design Suite), and now the serial number are not good. I tried to reset the activation, and that did not work. I have called the 800 number and no answer. I hope I can get some help here.
I have just activated using the activation codes from your download center on my end. Is there an error message you get when you are trying to activate?
