Error with Datassist and html Editor Error undefine when building
Im getting the following errors when i add an html editor field on an insert or update page using the dataasist wizard:
An error ocurred in the script on this page.
Line: 93
Char:1
Error: 'Ckeditor' is undefined
code:0
URL:root folders on my pc /appdata/roaming/adobe/dreameaver cc/en_US/Configuration/Shared/Webassist/Preview/Wafb/
And it ask me if i want to continue using the script yes or no
it makes datassist go pretty heavy and in some occasions crashes DW, has happened to me before when i had Dreamweaver cs5 and now that i upgraded to CC its the same still having that error on every single page that is created with data assist.
Also after i hit to stop the script or run it when the page is done the html edito when runing is not display i have to change the theme in order it to work
