Dreamweaver crash, again again
Thread began 8/29/2013 12:20 am by ma414067 | Last modified 8/29/2013 6:27 am by Jason Byrnes | 692 views | 1 replies |
ma414067
Hello Webassist.
I've used webassist a lot over the years.
But i have soon had it.
First time using Webassist on CS6..
And every time i try to create pages with dataassist, it keeps shutting down/Crashing.
I've tryed:
Reinstall all the super suite.
Install the correct order (according to other forum) Ecart, Design,databridge etc..
Deleted the cache.
Made sure, that i got no old plugins.
And nothing helps
I have had this problem constantly with webassist, also with the dreamweaver cs5/5.5, but there atleast it worked sometimes, when you had a lucky day.
Sorry Webassist, the products and ideas are great, but the time used to make error searching, absorbs the time spared from using plugins.
Using Windows 8 32bit, and dreamweaver Cs6.
Regards
Matias
Usually when Dreamweaver crashes like this it is a memory leak problem, Dreamweaver is not very good about freeing memory it is not using.
things to try:
-Disable the Preview
-Close the Files and Server behaviors panel before running any wizards
-Restart the OS after deleting the Cache File
