Adding A Sort Order
Thread began 8/17/2009 10:04 am by rob294118 | Last modified 8/17/2009 1:54 pm by Jason Byrnes | 958 views | 1 replies |
rob294118
Adding A Sort Order
Once you get the results from the "Product Search" form, is there a way to allow the user to sort the results by different fields?
Thanks.
If you own DataAssist, you can add the Sort Server behavior. Please see the "Sorting by column links" Tutorial in the Solution Recipe section of the DataAssist support page:
dataassist/
