Log in expiry dates
Thread began 8/19/2013 7:25 am by Heckie | Last modified 8/20/2013 7:19 am by Heckie | 238 views | 3 replies |
Heckie
Log in expiry dates
I am setting up a 'concierge' system for a holiday location to allow guests to order food, wine etc.
I have set up a table called 'Guests' with GuestID, GuestUserName, GuestPassword, GuestArrival and GuestDepart.
What I would like to do is only allow their log in details to work between their check in (GuestArrival) and check out (GuestDepart) dates.
I have set up the standard login page with Username and Password which works, but I'm not sure about getting the dates to work.
If it is going to be too complex to do a date range, then I would like at the very least to be able to make the log in expire so that they cannot order stuff after they have left.
you would need to set the login page to store the arrival date and the departure date in session variables
in the access rules, you will want to use time() to return the current time stamp, and strtotime to convert the dates in the sesson variables to a time stamp
the access rule settings will look like:
Allow IF
Value: <?php echo strtotime($_SESSION['arrivalDate']); ?>
Criteria: >=
Compare To: <?php echo time(); ?>
Allow IF
Value: <?php echo strtotime($_SESSION['departureDate']); ?>
Criteria: <=
Heckie
Thanks Jason.
I followed your instructions, but it is not working properly.
It is still allowing me to use log in details with an expired date, and also when I click 'logout' - I am able to access the site and place orders (although there are no session variables active) and it doesn't return me to the log in page.
Heckie
OK - I got it to work, but I had to use 'Restrict IF'.
