buttons not working
Thread began 8/15/2013 4:02 pm by dcb286193 | Last modified 8/23/2013 1:33 pm by pistartech366237 | 2787 views | 16 replies |
dcb286193
buttons not working
I have installed twice PowerMessage and both times the buttons on the mailing_design.php do not work. "Get From Page" or "Browse" do not even open and the "Get From Template" does not allow me to select anything, it's blank. Plus the cancel button . . . basically all the buttons on the page do not work.
Most likely there are files missing on the server.
makse sure that all tjhe files from the js folder are uploaded.
if you continue to have problems, I'll need to troubleshoot directly, see the private message section.
dcb286193
I used original zip file and replaced the js folder and still no luck with the buttons working.
Originally Said By: dcb286193
dcb286193
Makes sense
in the admin_pm/mailing_design.php page, line 469 had somehow been changed to:
$dirname = "webassist/emailtemplates";
i changed it back to the correct code:
$dirname = "emailtemplates";
to correct the problem.
dcb286193
Thank you Jason, I'm sure I just screwed it up somehow. Glad to see it working.
you're welcome.
pistartech366237
Hi Jason,
I've went through all threads on the forum that had something to do with the button problems but couldn't find the solution.
My problem is the following:
I've created all pages using DataBridge v.1.1.4 Security Assist. Everything has worked OK. However, when I have applied the Template, the forms have lost their format. Then, I have used the Forms ->Insert New Form option to apply the new design and to change several field names and validation texts. After which, the "Register" button on the registration.php page has stopped working (the click would not submit the form nor it will insert the new user record into the DB)...
I've tried everything, including re-creating these pages, re0installing the DataBridge extension, deleting WinCache file - nothing solves the problem.
The page is attached.
Please advise.
Thank you so much in advance.
