File Manager and mysql
Thread began 8/14/2013 8:55 pm by Ericspecullaas | Last modified 8/15/2013 1:48 pm by Ericspecullaas | 328 views | 2 replies |
Ericspecullaas
what im attempting to do is have file manager make new folders then upload images to them. that works perfectly!!!!! so no help there.
My second part is a bit tricky. I need to store the folder location in the mysql and retrieve all the uploaded images to be be loaded. The hole point of this is on the page i need to load a new slideshow with 6 images. then when a button is pressed it loaded them into the slideshow.
you wont be able to accomplish this the way you are going about it.
add 6 file form fields to your page, and add six upload file server behaviors to upload the files.
if you insist on using a the File Manager, you will need to have six of them.
in each one, select and image.
Then use the insert record behavior to store the selected file names. each file manager instance can only pass one selected file name, you cannot use 1 file manager instance to pass multiple file names.
Ericspecullaas
thanks was think that it would be easier with file manager since it does bulk upload.
