eCart completely crashed
Thread began 8/13/2013 3:28 pm by mrsam5266 | Last modified 8/17/2013 5:29 pm by mrsam5266 | 263 views | 4 replies |
mrsam5266
I had everything working fine until I made a change to the navigation on the cart page and now none of my Add To Cart buttons work. I open on of the shopping pages, click on the button then when I view the cart it says that the cart is empty.
I had previously tested every ATC button on all the pages and everything was working fine.
mrsam5266
Hi Jason,
The information you need is in the private section
the eCart code that should be above the doctype tag on your pages has been deleted.
Looks like Dreamweaver is deleting that code when you make changes to the template and update the pages.
You can prevent this from happening by converting your template to Theme using framework builder and using the theme on your pages instead of the template.
Using themes has the advantage of separating the page from the template. When you make changes to the template, you will no longer need to update the pages for the change to be applied, the template gets applied to the page at run time rather than having to apply the template to the page and re upload all files.
Another option to think about is to use the plugins to add the menu to the template. Create a new page, add the meny to the page and use Frmework builder plugins to add the menu.
We will be having a webinar this weekend on using Framework builder:
http://www.webassist.com/products/framework-webinar
we will be covering topics such as plugins and themes to give a more comprehensive over view of using them.
there is also a tutorial here for using themes:
http://www.webassist.com/tutorials/Using-themes-in-Data-Bridge-and-Design-Extender
and this one is a general getting started guide for Framework builder that touches on using plugins:
http://www.webassist.com/tutorials/Getting-Started-with-Framework-Builder
mrsam5266
Just to try and get the cart page working I rebuilt that page, deleted all the checkout pages and regrenerated those checkout pages. I still get "Cart is empty" when I go to one of my Add To Cart buttons then view the cart. Is this because the product pages are suffering the same fate as the cart page and having the top php deleted by the template? I really didn't want to have to redo all those pages but it looks like I might have to.
Yep, That was it. Rebuilding the pages with the ATC buttons.
