Cart error editing ECart object
Thread began 8/12/2013 5:37 pm by Supreme Geek | Last modified 8/13/2013 2:19 pm by Supreme Geek | 587 views | 4 replies |
Supreme Geek
Every time I adjust my Columns and Calculations to add a new type of item to the ECart the item that I added works fine. But, I have to go back through all of the items again and select the "cart.php" file to get the other items to work. Is there a faster way so that I don't have to go back through all of the items and select "cart.php?" Here is the error that I get if I go and try to add an item to the cart after editing the cart:
Warning: Missing argument 23 for eCart1_Definition::AddToCart(), called in /home/content/l/o/t/lotcsadmin/html/WA_eCart/casual.php on line 200 and defined in /home/content/l/o/t/lotcsadmin/html/WA_eCart/eCart1_PHP.php on line 28
Warning: Cannot modify header information - headers already sent by (output started at /home/content/l/o/t/lotcsadmin/html/WA_eCart/eCart1_PHP.php:28) in /home/content/l/o/t/lotcsadmin/html/WA_eCart/casual.php on line 503.
Recently I also updated to Dreamweaver CS6. But, I still had the same problem in CS4 when I updated the ECart object columns and calculations.
Thanks,
Any time you add a new column to the cart object, you will need to edit the Add to Cart behavior on each of the pages of your site.
The add to cart behavior generates the code based on the current collection of columns in the cart, if one is added, it will need to be regenerated.
There is not another way of doing this other then editing the add to cart behavior.
Supreme Geek
Jason,
Is it possible to do this globally to the add to cart buttons? My home number is: 503-895-8159....
Thanks,
No, there is not a way to do this globally. you need to edit each add to cart button behavior.
Supreme Geek
Thanks Jason...Someone needs to write a program so that the changes are made site wide....just a thought...
Later...
