i get an error message when i try and insert any web assist tool. like a button or anything else.
see attachment. tells it all. i get this for all attempts to apply any web assist tool.
Make sure to download and install the latest version of Data Bridge from our web site. The error you are seeing is because Adobe removed the Form Insert objects in the latest version of Dreamweaver, but the latest version of Data Bridge should add them back again.
i did the download and upgrades for both design extender and data bridge. still get the same message. not working.
Did you try closing Dreamweaver and deleting your winfilecache.dat file? If that still doesn't work, post your phone number and we can give you a call to look into it further.
forgot how to do that. refresh me?
Are you on a PC or mac? There are instructions on doing it all over this forum.
You need to go to your users configuration folder with Dreamweaver closed and delete it from there... on pc you can get there by using:
%appdata%/Adobe/Dreamweaver [dw version]/en_US/Configuration
just start by typing %appdata% into windows explorer and drill down from there.
trying to add CSS Button within an existing HTML doc.
most of the other WA features work. not this one.
That file should be installed with the latest version of Data Bridge... maybe post your phone number in the private area of a reply and I can call you to debug what is going on.
