Powerstore website is not working
Thread began 7/31/2013 5:27 pm by vallvic484439914 | Last modified 8/06/2013 8:59 am by Ray Borduin | 1470 views | 9 replies |
vallvic484439914
My Powerstore has run great for over 2 years now but I am now having major issues getting onto my website www.v2fineinteriors.com . Some pages work fine but most dont. I can access my admin pages with no problem. I have contacted Godaddy and after they ran several tests they have come to the conclusion that it is not them:
Dear Sir or Madam,
Thank you for contacting Online Support. I am able to duplicate the 500 internal server error when trying to parse PHP files on your site. I enabled detailed errors and can confirm the error is related to FastCGI on PHP. I have uploaded my own PHP file and this file loaded without an issue. That being said, I have come to the conclusion that not all PHP files are causing this error.
Because we do not provide coding support, we are unable to determine what specifically in your code may be causing the error. You may wish to review your code to determine if there are any issues, because it appears that is the most likely cause of the error. You may also wish to enable detailed error messages as a temporary diagnostic measure. The procedure for this will vary, depending on the scripting language being used. We also recommend consulting both the vendor's online documentation, as well as the large number of online forums dedicated to coding and scripting.
Let us know if we can assist you in any other way.
All the Best,
Donovan J.
Online Support
At this point I am at a lost on what to do... I launched my company this month and this is hurting me pretty bad. Any help would be great.
Thank you
Victor
vallvic484439914
See Private message.
Originally Said By: vallvic484439914
vallvic484439914
message
Ok, I see
vallvic484439914
errrr talk about bad timing I just called godaddy and there systems are down. I will get back to you as soon as they resolve the issue. Thanks a bunch for the fast replies I really do appreciate it!!
vallvic484439914
Ok Jason you should be able to access it now.
It appears to be a server configuration issue. I added code to the first line of the index.php page:
<?php die("here"); ?>
That should just write "here" to the page and not run any of the code on the page.... since I don't even see that and the page hangs and errors that means it isn't even getting to the page. So it must not be an issue with the powerstore code itself. It is an issue with the server not getting to that page.
I'd contact your hosting provider to get help accessing your site. They should be able to get it resolved.
vallvic484439914
Thanks for the reply. Godaddy got it working again. Hopefully it stays fixed.
Thanks Again!!
