PPal Express error on checkout
Thread began 7/29/2013 2:48 pm by massimo173451 | Last modified 7/30/2013 2:56 pm by massimo173451 | 1116 views | 14 replies |
massimo173451
On web site, choosing the product free of charge (zero cost) or with payment in the cart, on checkout with PPal express the transaction fail, and is not asked the user authentication why (the payment gateway, in the Admin page, are only:PP Express Only, PP Payment Pro,Authorize.net)??? The PS version is 4.5.3, the web site tessyacconciature.it
In the admin section enable debug mode, that will help us determine the response from paypal express to see why it failing.
massimo173451
just enabled
ok, so what is the response?
do you have a link where i can see the problem?
massimo173451
Try yourself, add a product ( eg.:photo) to the cart for reproduce the error (note when go to the payment the page doesn't ask the user authentication):
try this link: http://www.tessyacconciature.it/products_results.php
The response back from paypal is:
Security error
Security header is not valid
This means there is a problem with the API Credentials you entered. it may be that you used LIve ApI Credentials, but the store is set to use the sand box, or vice versa, or it may be that you have not accepted the API Billing agreement with paypal.
massimo173451
Jason, I have created the API credential and works fine when in the cart have a product to puchase, but when insert in the cart a free product (digital product) get the error "2013-07-30T11:50:44ZFailuree76b4d2fb0b50Invalid DataThis transaction cannot be processed. The amount to be charged is zero.10525Error63.07066343" ["WA_HTTPS_Redirect"]=> int(0) }. This error is in debug mode, and modified the code in process_transaction.php:
if($WA_Store_Cart->GrandTotal() == 0) $WAGLOBAL_Test_Mode = true;
if ($WAGLOBAL_Test_Mode != true) {
but the transaction with PPal is not by passed, if in the cart have a free product (zero cost). Have you a further suggestion??? Thank you
add that code to the webassist/plugins/shopping_cart/pp_expressform.php file.
massimo173451
Jason, where I can add the code??? Receive a syntax error
my applogies, this line:
should be in the webassist/plugins/shopping_cart/cart_editable file.
change:
$WA_Store_Cart->GetContent();
