Problem with forms after menu update
Thread began 7/25/2013 6:23 pm by Sally | Last modified 7/26/2013 1:25 pm by Sally | 293 views | 4 replies |
Sally
I have a page that sends an email with attachment to HOA residents and then uploads/inserts the attachment into a database. There's another page that is similar except that no file is inserted into a database. They've both worked fine for a couple of years but I recently made a menu change (added one line: <li><a href="../../Webcam.php">Webcam</a></li>) to menu.php and now they both don't work properly. For the one that emails everyone and inserts a file into a database, the form errors out saying it can't connect to the site while actually sending two copies of the email and uploading two files into the database. I suspect it is caught in a loop and would do it even more but the server stops it. The form that doesn't insert a file into the database but just sends out an email gives me an error that says Error code: ERR_CONNECTION_RESET but the email is sent.
When I made the menu change I uploaded the 'CSSMenuWriter' folder and the 'webassist' folder. The menu change is the only change I've made and I can't find any reason for this problem to occur.
Any help would be greatly appreciated. Thanks
Sally
Okay - thank you.
See PM:
Sally
Sounds good. Thank you very much. I will copy the webassist/framework files down to my local machine too.
