Power store - registration page
Can a captcha be added to the 3 line registration form - i'm getting spam registrations
if you have Data Bridge, you can edit the simple registration form to add captcha and edit the server validation server behavior to add validate the captcha input.
if you do not have data bridge, it will require copying the necessary code from the advanced registration form and adding it to the simple registration form.
if you need help setting this up, we can help you implement this in a premiere support appointment
