Need help to create a seesion/cookie or ?, that enables my security assist show region UserGroupId validation. I used the tutorilial User-depentend-Menu Options
Thread began 7/23/2013 12:45 pm by stefanvb | Last modified 7/23/2013 3:29 pm by stefanvb | 425 views | 4 replies |
stefanvb
Need help to create a seesion/cookie or ?, that enables my security assist show region UserGroupId validation. I used the tutorial User-depentend-Menu Options
Following the tutorial it was easy to get the show region assistant displaying and hiding menu items, if a user is logged in or not. It seams, that I am unable to make the special access rule for useres working. The number in the table UserGroupId, that i created before having security assist building pages, is not getting recognised during a session. My mistake, I guess is, that I am not able to write a proper session behaviour for saving the UserGroupId while a user is logging in. I tried for 2 days, but I don't get any further.
edit the Security Assist Authenticate User server behavior on the login page.
go to the session tab, click the Plus button and select the UserGroupId column to have it saved to a session at login.
stefanvb
Thanks you Jason, found it, but making mistakes editing the SecurityAssistAuthentiucateUser - Server Behaviour. I am getting as a result on my index page Notice: Undefined variable: b1_bago in /Applications/MAMP/htdocs/dynamic_site/TMPXKUKUB.php on line 3
Warning: mysql_query() expects parameter 2 to be resource, null given in /Applications/MAMP/htdocs/dynamic_site/TMPXKUKUB.php on line 3
Stefan
b1_sLogin.php
this error means that the page is not able to connect to the mySQL server.
make sure the mamp MySQL Service is started, and double check that the connection details entered in the Connections/b1_bago.php file are correct.
stefanvb
Got it Jason, there was some weird php code on my index page. Your threads are simple, clear and helpful in general. I feel realy honored, that I could personally participate. Magic, its working now. Thanks a lot!
Stefan
