Directions based upon user mobile location
Thread began 7/23/2013 2:38 am by HHar21498653 | Last modified 9/22/2014 4:39 am by Jamie | 1510 views | 21 replies |
HHar21498653
Is there a way to have the directions using the GPS coordinates as the "from" on the mobile as the starting position? (step 5 in the pro map wizard).
I like to use the Pro Maps in a mobile environment, I can enter address where to go but I like to have the driving directions based upon where I am.
If that is not possible is it possible for the user to enter their location and then have Pro Map use that as a "from" address.
Henk.
you would need to hand code the ability for the web page to get the users address:
http://diveintohtml5.info/geolocation.html
as for user entered address, create a form that the user can enter there address, then in the Pro Maps wizard, on the directions screen, click the lightning bolt next to each of the direction elements and select the corresponding form elements.
CraigRBeta Tester
Hi Jason,
just started looking at this.
I can extract the geolocation using the code on the google developer site
https://developers.google.com/maps/documentation/javascript/examples/map-geolocation
However the pro maps for google wizard does not cater for co-ordinate input.
Is there a way around this ?
once you have the latitude and longitude, you can lookup the corresponding address, for example:
http://maps.googleapis.com/maps/api/geocode/json?latlng=42.5,%20-70.89&sensor=true';
you could use that result to pre-populate the address fields in the address form.
i found an example from a google search search for:
get address from html5 geolocation
http://techslides.com/html5-geolocation-address-form-filler/
CraigRBeta Tester
Thanks Jason, - i couldn't get the demo to work, but I got the idea.
I used the url you provided - so I can retrieve a json file using co-ordinates, and from the array, i can recover a postcode.
One issue i came across is that the array generated from the json does not always seem to have the same number of elements,, is there a way to always be able to select a postcode ?
eg, in this code snippet
$geoCodeURL = "http://maps.googleapis.com/maps/api/geocode/json?latlng=".$lat.",%20".$long."&sensor=true";
$result = json_decode(file_get_contents($geoCodeURL), true);
@session_start();
$_SESSION['retrievedpostcode'] = ($result['results'][0]['address_components'][4]['long_name']);
gives me the postcode, for a particular UK address, but this array value (4) is not a postcode on the url you provided
Other than this, i have a working example, just needs a bit of tidying
honestly, Craig, I dont know, this would fall under the premiere support category.
CraigRBeta Tester
Thanks Jason,
Looks like you can restrict the values returned in the url, which may do the trick.
https://developers.google.com/maps/documentation/geocoding/#reverse-restricted
ok, cool.
CraigRBeta Tester
Please test
Ok, still work in progress, but I have a working version.
If this solution is sufficiently robust, I may write a tutorial.
Here is the page,
http://whitehouse.forthwebsolutions.com/findus.php
the option to 'Get Directions from current location' is only visible when the browser window is 768px or lower (ie mobile devices)
Grateful if anyone is prepared to give it a go, and let me know if it works ok.
Didn't work for me, but then I am in the US so driving Directions to the UK may be difficult.
