Login design
How I can change the template, the text filed put more bigger and change the template for one that I have
The login form design is not a tempalte.
The login form design is controlled by css.
to make changes to the login form design, you need to edit the css.
The Firebug extension in Fire Fox is helpful for examining page elements and finding the css that controls them to determine where edits would need to be made:
http://www.webassist.com/tutorials/Using-Firebug
as for replacing the login form with your own, you could do this, but make sure that the form action, and the names of the form elements are the same as the original.
Ok, Thanks
When I login to the page that is in a security page how I can put the name of the person that is login in the top of the page and how can make a rule that if I left open the page for 25 second automatically redirect to the login page
edit the Security Assist Authenticate User server behavior that is on the login page.
On the Session tab, click the plus button and select the Users name column to store that in a session.
On the page you wish to display that, go to the bindings panel, expand the session collection and add the user name session to the page.
to redirect after a period of inactivity, you would need to add custom coding such as using the following JQuery plugin to track activity:
http://www.paulirish.com/2009/jquery-idletimer-plugin/
